Sierra rear drive shaft thread
Old Sep 21, 2018 | 02:25 PM
pauloopnorth's Avatar
pauloopnorth
Default Sierra rear drive shaft thread
Can somebody please clarify which side of the car has the revers thread on the drive shaft stub, Sierra 4x4 Cosworth
Old Sep 21, 2018 | 05:51 PM
Caddyshack's Avatar
Caddyshack
Passenger side on a right hand drive car. I.e. nearside. REAR
Old Sep 21, 2018 | 11:32 PM
timsrs's Avatar
timsrs
Near side rear
off side front
left hand thread is identified by a notch in the nut
Old Sep 22, 2018 | 03:21 PM
Ridgey's Avatar
Ridgey
So Rear nuts are in direction of tyre rotation?
and
Fronts are in opposite direction to tyre rotation ?
Old Sep 24, 2018 | 11:27 AM
Caddyshack's Avatar
Caddyshack
and
That does not sound correct to me.
Drivers side rear (offside) is conventional nut so would be anti clockwise to tighten it therefore not direction of tyre rotation. All I know is that the REAR passenger side is a reverse thread as I found out the hard way when I put a powerful impact gun on it and snapped the thread due to thinking it was a normal thread.
Old Sep 25, 2018 | 05:16 AM
Marc sierra's Avatar
Marc sierra
The fronts on a 2wd car are tightened from the inside of the car, the rears are tightened from the outside hence the different thread. On a 4x4 the fronts both have normal (RH) thread and you need to knock a small piece of the nut into a recess in the driveshaft to prevent it from loosening.
Old Sep 25, 2018 | 07:33 AM
pauloopnorth
Thank you everybody that has replied
skypeller
May 10, 2015 05:36 AM
Thanasis
Apr 17, 2015 09:06 AM
Blakeya
Dec 7, 2005 07:52 AM
