car has lost 2nd 4th and reverse gears
Old Sep 4, 2018 | 07:34 AM
RetroTed's Avatar
RetroTed
Default car has lost 2nd 4th and reverse gears
AS per the title
Driving home I have lost 2nd 4th and reverse on my Sierra 4x4 J plate. I can select 1st 3rd and 5th but it seems that the neautral has moved further back towards the handbrake if that makes sense
Any ideas ?
Old Sep 5, 2018 | 09:32 PM
The Youth.'s Avatar
The Youth.
its possible 2 of the 4 linkage bracket bolts have come loose and fell out
lift up the 2 gaitors and have a look or get underneath and have a look
seen it before
edit read it again i'm certain the 2 front ones have fell out the linkage bracket is lifting at the front as you pull the gear lever back
Steve
Old Sep 6, 2018 | 07:31 AM
RetroTed's Avatar
RetroTed
seen it before
Steve
Steve you are correct, the 2 forward bolts had come loose allowing the bracket to tilt backwards. Not an easy fix but certainly a cheap one
Old Sep 6, 2018 | 04:14 PM
cossynut2's Avatar
cossynut2
10 Year Member
Nice one!!
Old Sep 10, 2018 | 11:54 AM
The Youth.'s Avatar
The Youth.
good news, it had to be that!
Steve
RetroTed
Sep 4, 2018 03:06 PM
