mk1 transit supervan tribute
Old Sep 3, 2018 | 11:53 PM
bj928's Avatar
bj928
Default mk1 transit supervan tribute
Well i finally found a mk1 transit worthy of cutting about, i'm calling it a tribute because it will have mk1 escort bubbles to give it the look of the original supervan, but may not be 100% exact to the original, it will also have a v8 engine mounted in the middle of the van, just like the original, but it will be the newer coyote 5.0 from the 2015 mustang, although to help with cost a little it may be coming from an F150, they are slightly lower power, but almost the same engine, the back axle will be full independent from the 2015 mustang, this part i already have, and will be the first part going on, will go with gartrac arches as it seems they are the best available, to save on hastle, it will have the shortest prop shaft i can use to keep the original auto box, the modern engines have flappy paddle controls, so it acts like a manual, and thats a lot easier than trying to change a manual gearbox behind as the 6 speed manual option isn't cable, although the mustang gearbox is the MT82 as found in transits and they are cable, so it would be an option, but i like the idea of flappy paddle, front crossmember hasn't been fully decided yet, although it will more than likely be based on a msutang2 setup as found on hotrods everywhere, but it may have to be modified to include some kind of drive, as it may go 2/4wd,
the plan is to do a dummy build and get it moving and driving under its own steam, then next year buy the parts to build the engine up to take twin turbos, this is the reason for the 4wd option, 1000hp through 4 wheels will get off the line better than the same power just to the rear, and also next year will be the time to buy the correct offset alloys, hoping i can run -44 offset to get a mega deep dish 12 or 14 inch on the rear, and maybe 10 inch on the front, exhausts will come out in front of the rear wheels, and the idea of side loading door on both sides is for when its on show, i can open both doors and have engine sat there, i wanted to go the transaxle route, but the cost was stupid, so thats why its getting normal set up with really short prop, the engine and gearbox complete is only 63 inches, so might just have the front of the engine between the seats, but only just at the back of the seats, i will know more once i get the engine and it can be measured, but going by info from the net, thats the length, i wanted a van, not a bus, but twin door short wheel base vans are like hens teeth, so had to take the bus, needs a little restoration as we go, and the windows will be changed for perspex or race car window plastic.
Old Sep 4, 2018 | 01:24 AM
visa_broke's Avatar
visa_broke
10 Year Member
Looking forward to seeing this progress. Very interesting project
Old Sep 6, 2018 | 09:37 PM
IanC's Avatar
IanC
Looking forward to this one coming together
Old Sep 7, 2018 | 07:35 AM
MONSTER's Avatar
MONSTER
Interesting project, look forward to the updates
Old Sep 10, 2018 | 09:53 AM
rog's Avatar
rog
This will be awesome, good luck with the build.
Old Sep 11, 2018 | 12:19 PM
Now this will be a very cool project.
Old Sep 11, 2018 | 10:00 PM
bj928's Avatar
bj928
this is the rear axle i have already, 2015 mustang GT axle, LSD, 3.15 ratio, discs and calipers, everything you see, just $400, should be the perfect width as well, will be replacing the shock and spring, with a coilover,
Old Sep 12, 2018 | 10:04 AM
R4N SS's Avatar
R4N SS
interesting project - take it you are still in the states then?
Old Sep 12, 2018 | 05:08 PM
bj928's Avatar
bj928
yes, still in the states till end of Nov, beginning of Dec, should be getting a donor vehicle for the engine and box soon, got my eye on a 2018 f150 with a generation 3 engine and 10 speed auto/manual shift, or a 2016 mustang with 6 speed auto/manual shift, got to see what comes up at what price
Old Sep 13, 2018 | 09:23 PM
RichieST's Avatar
RichieST
What a cool project, looking forward to seeing the updates!
Old Sep 27, 2018 | 06:25 PM
bj928's Avatar
bj928
well i got my donor vehicle, 2018 Ford F150, latest generation of the ford coyote v8, wanted a mustang engine really, but they were just to much, but the one in the F150 is basically the same as the 2018 mustang, just 400hp where as the mustang is 460hp, both 32v v8 engines
Old Sep 27, 2018 | 09:02 PM
PAUL V's Avatar
PAUL V
Nice one, what sort of money is a truck like that ?
Old Sep 28, 2018 | 03:01 AM
bj928's Avatar
bj928
cost me $3018, which i think is a bargain as its go the new 10 speed auto with manual select, i've already got a mustang steering column with wheel thats got the flappy paddles, should be able to get them working with the gearbox, as the steering wheels in the f150 is the same almost as the mustang
Old Sep 28, 2018 | 07:37 AM
Cool progress. What a shame about that pick up.
Old Sep 28, 2018 | 09:04 AM
RichieST's Avatar
RichieST
This will be so cool when its done!
I saw something on the telly recently, a ford pickup is sold in America on average every 27 seconds. So not like there is a shortage of them!
Old Sep 28, 2018 | 03:22 PM
focusv8's Avatar
focusv8
Don't worry, there's hundreds more like it, well 159 anyway;
https://www.iaai.com/Search?Keyword=2018+f150
Old Sep 28, 2018 | 03:30 PM
haz87's Avatar
haz87
Cool build!
Old Sep 28, 2018 | 05:27 PM
XRT_si's Avatar
XRT_si
This will be epic!
Old Sep 29, 2018 | 01:33 AM
bj928's Avatar
bj928
once its together and working, the engine is getting forged internals rated at 1500hp+, and a pair of turbos, these engines are 12:1 compression ratio, and they seem to be coping with 10psi in factory stock trim, so with forged internals it should take plenty more boost, and hopefully if i don't go to big on the turbos i can keep the lag down, i'm still learning about turbos and whats best, so will need advise on that, at the moment a pair of gtx 3076 maybe, or similar, maybe someone could tell me if this will work and lag will be minimal
Old Oct 3, 2018 | 12:28 AM
bj928's Avatar
bj928
well i went and picked up the donor vehicle, and took all the damaged parts off i needed to so i could get at the engine and see if it had any visible damage, and the engine wasn't touched, other than a slightly bent oil cooler pipe that had touched one of the belts, but that was soon sorted, cutting the AC lines, was most shocked, the AC was still fully charged, so what a result, these engines and boxes are going for $10k on ebay, i only paid $3k for the complete truck,
Old Oct 3, 2018 | 02:02 AM
visa_broke's Avatar
visa_broke
10 Year Member
How much was shipping to get it over to you?
Old Oct 3, 2018 | 03:30 AM
bj928's Avatar
bj928
i'm working in the states, so went and got it myself, shipping to the uk won't be bad, either in a container i ship myself with loads of other bits, or a big crate and send it groupage
Old Oct 3, 2018 | 07:22 PM
Can wait for the updates ,good luck with the build
Old Oct 7, 2018 | 05:27 PM
PAUL V's Avatar
PAUL V
Massive bargain that, and thanks for shareing
Old Oct 7, 2018 | 06:02 PM
visa_broke's Avatar
visa_broke
10 Year Member
Where abouts in the states are you working?, I'm working just north of NYC currently.
Old Oct 9, 2018 | 01:17 AM
bj928's Avatar
bj928
i'm in Bismarck, North Dakota, so a long way from you, i want to get to NYC some time, guessing NYC is New York City, to see new year in.
Old Oct 9, 2018 | 01:37 AM
visa_broke's Avatar
visa_broke
10 Year Member
I'm currently up near Rochester/Niagara falls but will be back in NYC maybe next few weeks. I have Washington soon.
I don't know much about ND, we don't ship much out that way, maybe ten to twenty packages a month.
Wish shipping was cheaper to the UK, I would send more back over.
Old Oct 10, 2018 | 02:00 AM
bj928's Avatar
bj928
from NY shipping should be cheap if collected from port, all your paying for is the boat bit, thats the cheap bit
Old Dec 20, 2018 | 11:41 PM
PAUL V's Avatar
PAUL V
Any updates mate ?
bj928
25
Oct 3, 2018 06:21 PM
Mattcortina
Ford Range
Dec 4, 2016 05:27 PM
gus
Jul 17, 2010 07:26 PM
FezzaBoy87
Aug 18, 2009 08:16 PM
ProjectBobcat
12
Feb 13, 2005 05:28 PM
