General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
I’d be very careful if it don’t have a proper swirl pot in it you can get issues. I put one in mine with a metal swirl pot design in it. Mine did have 500bhp at the time but with the new tank it surged its arse off.
I can't get the product mentioned here in NZ. I can get a POR 15 3 stage fuel tank repair kit though. It has a cleaning solution, a metal prep solution and a tank sealer. has anyone tried this?
https://www.por15.com/POR-15-Fuel-Tank-Repair-Kit
I'm not sure how the sealer will go with the swirl pot though.
Ah yes NZ could be a problem. There are many other solutions used to remove rust and won't affect plastic give it a Google vinegar can be used.
At work we deal with a lot of vintage tanks which on some occasions we just rinse out and reuse due to cost and time. The fuel filter will pick up 98% of any rust.
Any chance of a picture to see how rusty it is?
Maybe get the tank chemically dipped if possibly and re galvanised as I am sure this was done when manufactured.??
Mines has a new pattern part tank, if I have any surge issues I’ll just fit a small swirl pot underneath
what sort of thing have you in mind for s swirl pot underneath
reason I ask is I’m in the same boat as you
and fitted a pattern tank
so would like to know what sort of thing you mean
cheers
Mine has a swirl pot in the boot along with the pump that feeds the rail. Certainly not everyone’s cup of tea but mines far too modified now to worry lol
It makes a change to seen a proper genuine tank with the plastic swirl pot! Shame to take that out if you can clean it and re use it
looks neat Andy. I have been running my Cortina like that for many years (before I took it apart) with no issues.
Did you use the std pump to fill? I am using a Holley blue.
correct me if I’m wrong but aren’t the pump supposed to be gravity fed
My swirl pot is fed by an 044 the swirl pot now feeds the pump m.a.d recommend for big horse power. My after market tank surged its arse off first time it came on boost lol. As above it ran with no issues. I only changed my tank as I got the new one and had dash fittings welded on
I know you are probably not to but do not use the POR 15 in an original tank because it is a coating which seals the tank and will clog up the internal filter which sits in the middle of the plastic swirl pot,
the pattern tanks don’t seem to have an internal filter.
something like this, I searched my pictures as I’ve saved one from an escos but couldn’t find it
as you’ll see from the description there’s a -6 feed from your lift pump to fill the pot, -6 return from the pot to your main tank, -8 feed from the pot to your fuel rail/extra pump then a -6 for the return fuel from the outlet of your fuel rail
I considered one under my car but there isn’t that much space under a saff. And as mine will never go to the shops shopping my only interest in it is how quick I can get it so went with the one I have. Plus as I got to pick the dash fittings it supplies the pump that feeds the rail with a dash 10 as they do out the tank. And the feed into the swirl from the 044 is dash 8 as it is to my fuel rail. Mine was an after fault that only came about because of the after market tank
Your right lots and lots of different opinions and advice on the net mate. All you can do is pick your tuner and follow there advise. Or work out your own route
Thanks Adam
not seen this type before
just to be on the safe side I’ll think I’ll fit one of these
where did you mount yours out of interest as I can’t find your post
