rear number plate trim removal
Old Aug 26, 2018 | 06:19 PM
Russ6334's Avatar
Russ6334
Default rear number plate trim removal
Hi all
may seem a stupid question but anyone know how to remove the number plate trim?
looking on the inside it appears screwed in back to front but looking at back there is no screw????
Old Aug 26, 2018 | 06:20 PM
Russ6334's Avatar
Russ6334
Originally Posted by Russ6334
Hi all
Screw is here
And there it is from rear!
Old Aug 26, 2018 | 08:31 PM
costina's Avatar
costina
Live long and prosper!!
Remove lights and number plate. Using a plastic trim tool it will prise off.
Old Aug 26, 2018 | 08:33 PM
Russ6334's Avatar
Russ6334
perfect thanks
Old Aug 26, 2018 | 08:40 PM
costina's Avatar
costina
Back in the day all us 2wd boys fitted the smoked rear lights and number plate surround to make them look newer. I used to remove the studs and use double sided number plate tape and the number plate fixings to hold mine on. Many drilled the holes so had to have them welded up at later date when standard was the way to go.
How times change.
Old Aug 26, 2018 | 08:42 PM
Russ6334's Avatar
Russ6334
How times change.
haha that makes me laugh cause today I was thinking about putting the side repeaters back to yellow from clear!!!
The money is in originality when they become classic I guess!
Old Aug 26, 2018 | 08:47 PM
costina's Avatar
costina
Bloody original old stock sides are really expensive seen them for 100 quid for a pair.
Old Aug 26, 2018 | 08:48 PM
Russ6334's Avatar
Russ6334
really? eBay has loads for Ł15! Unless they are non original
Old Aug 28, 2018 | 02:28 PM
R4N SS's Avatar
R4N SS
those would be non original - crazy the money being asked for parts now
Old Aug 30, 2018 | 04:33 AM
4x4kiwi's Avatar
4x4kiwi
As an answer to the original question. I asked the same question a few years back. here is a link to the thread.
https://passionford.com/forum/ford-s...ate-panel.html
David
Old Sep 6, 2018 | 07:51 PM
The Crocodile Hunter's Avatar
How times change.
exactly how mine was when I bought it back in 05
Joshknight605@gmail.com
Ford KA
Feb 2, 2018 06:54 PM
RS_Cosworth330
Jul 29, 2012 07:28 PM
kosienutter
Jun 7, 2010 04:40 AM
Beach
30
May 28, 2005 12:32 PM
Ryan
14
Oct 30, 2004 03:57 PM
