Ford Fiesta 1.3L 2002 Idle Issue
Hi All, having some issues with my ford fiesta, it's a 1.3L 2002 plate, been told today the engine is possibly the same as they put into the Ford KA.
When the clutch is down/idle the revs will increase to 2500 RPM and drop to 1500 RPM without me pressing anything and this is a continuous cycle so sounds like i want to race the person next to me which clearly isn't the case.
Wondered if this is a common issue / If there are any known fixes?? possible Idle control valve issue??
All feedback is greatly appreciated!!
If it has a idle speed control valve(iscv) I would change this first.
What I've done in the past is took them off cleaned them out with brake CLEANER then let the soak in brake FLUID over night.
LHD220Turbo
May 7, 2010 08:20 PM
Stavros
Jan 22, 2005 08:13 AM
