4X4 Cosworth gearbox issues after rebuild.
Evening all,
I've just had my gearbox rebuild and it's drives mint and selects gears perfect on the twisty stuff, however after a long straight run say like on motorway if I come off and to a stop I cannot select a gear.
I have to pretty much ram it through the dash to try select first & second is a pain as well. I had to pull away from a set of lights earlier in third! Then come out later it's fine again.
Has anybody had similar issues like this? as its doing my head in!
Thanks all
Thanks all
I thought it was odd to, it's like its overheating something in there on a long run.
The've put in an ATF fluid that they were recommended to use. Spoken to Opie and they have advised me a different grade (75w90) so i shall try that and see if any better.
london_chris
Dec 23, 2016 08:42 AM
M K
Jul 31, 2015 02:09 PM
Mickyflint
34
Apr 23, 2013 07:23 AM
pacificzetecturbo
Jul 17, 2007 04:55 PM
