Coolant level sensor for Ecoboost engines
Old Jul 6, 2018 | 01:51 PM
Airbus's Avatar
Airbus
Default Coolant level sensor for Ecoboost engines
Hi All.
I've just bought a 2017 Titanium 125 Ecoboost and like many people I was surprised at how many modern engines manufacturers don't provide any method of monitoring the coolant level. Especial as its so important these days with engines so highly stressed and running so hot.
Over the next few days I will post my capacitive level sensor setup with pics if anyone is interested. Total cost to me was around £70.
Old Jul 6, 2018 | 03:27 PM
gcfcos's Avatar
gcfcos
Sounds good mate. I just normally open the bonnet at look at the coolant bottle
Old Jul 6, 2018 | 05:20 PM
RichieST's Avatar
RichieST
Why should you need a level sensor? Haven't ford cured the coolant issues on the ecoboom engines?
Old Jul 7, 2018 | 06:43 PM
Airbus's Avatar
Airbus
Looking under the bonnet at 80mph isn't that easy if a stone hits the rad or a hose goes without the driver knowing.
Old Jul 7, 2018 | 07:40 PM
studabear's Avatar
studabear
Could that only happen to a ecoboost engine then?
Are you spamming to try and sell a product?
Old Jul 8, 2018 | 12:18 AM
Airbus's Avatar
Airbus
Can happen to any modern engine with no coolant level sensor. In the old days of cast iron heads you just stopped and let the steam die down and topped up with water. Try that with an Ecoboost. Not selling anything, just sharing an idea.
I had a Zetec SE that leaked from the heater matrix pipe (common I think) didn't spot it at first but was about to do a 80 mile motorway journey and saw pink water on the driveway. That was a close one. Its up to you if you trust the once a week bonnet lift and check.
Old Jul 8, 2018 | 12:53 AM
Airbus's Avatar
Airbus
Sensor Siliconed to Exp Tank. So far it has reliably detected a 2cm drop in levels when I siphoned tank under test.
Old Jul 8, 2018 | 12:57 AM
Airbus's Avatar
Airbus
Circuit I used to run the warning Leds
Old Jul 8, 2018 | 01:05 AM
Airbus's Avatar
Airbus
Sensor fixed with silicone on Tank. Would probably work with any Capacitive sensor with a 20mm + detection range.
Old Jul 8, 2018 | 05:42 AM
Mark V8's Avatar
Mark V8
Not a bad idea! Could be used on other things like water injection or intercooler spray tank to give you a chance to ease off the throttle.
Are the resistors different values to make the red LED brighter than the green one ?
Old Jul 8, 2018 | 02:04 PM
Airbus's Avatar
Airbus
Mark V8. Yes well spotted, green is just a system ok lamp, red is full brightness warning, around 20mA. It can be made simpler by just running the red warning Led on its own but I have all the components at my work so I indulged in the luxury of both.
Old Jul 8, 2018 | 02:29 PM
studabear's Avatar
studabear
Sorry if my previous post came across a bit arsey. That does look interesting tbh. I was imagining some sort of float sensor in the header tank. So does your sensor work in a different way.
Old Jul 8, 2018 | 04:15 PM
Nice one matey. It nice for you to share your idea.
Old Jul 8, 2018 | 04:27 PM
THE RADMAN's Avatar
THE RADMAN
theres a recall for a lot of fords coming soon so they can be fitted with a coolant warning system,around half a days work or more ,the wifes st180 will need to go in
http://www.dft.gov.uk/vosa/apps/reca...25821000331F93
Old Jul 8, 2018 | 05:27 PM
smiley's Avatar
smiley
Good idea
Old Jul 8, 2018 | 07:58 PM
Airbus's Avatar
Airbus
Studabear. Yes it works by detecting the capacitance change caused as the liquid disappears out of range of the sensor. A bit like a metal detector. I used this idea as it doesn't require hacking into coolant tank and risking creating a leak that wasn't there in the first place.
Old Jul 8, 2018 | 08:05 PM
Airbus's Avatar
Airbus
Does the ST have a factory coolant sensor? I guess I could have got an ST sensor fitted if they have an official Ford solution.
Old Jul 8, 2018 | 09:00 PM
smiley's Avatar
smiley
You would think all essentials things would have level sensors factory my v60 I have to piss about with holding a button turning off then on just to check the oil why can't it be just thier on the scroll wheel lol
Old Jul 8, 2018 | 10:11 PM
martysmartie's Avatar
martysmartie
Hi All.
Don't really see the point tbh (clearly neither do manufactures) there must only be a few cars that have them (such examples being high spec Sierra and Granada's).
Martin
Old Jul 9, 2018 | 06:22 AM
smiley's Avatar
smiley
Lol tell that to the guy a bought a 63 plate ecoboost off for £500 after his hose blew off his header for the second time and cooked his engine now a 6.5k car again with £900 16000 mile engine
Old Jul 9, 2018 | 07:27 AM
Airbus's Avatar
Airbus
I think the main reason manufactureres avoid the addition of a sensor is the extra cost and false alarm issue they would have with customers. The coolant tank is baffled to help stop water sloshing around but it may still false alarm with a float switch if somebody brakes hard on a steep hill or similar. Doesn't bother me if it does, that just tells me its working ok.
Old Jul 9, 2018 | 12:05 PM
Why not just use a dip stick like the good old cars.
v man
Mar 14, 2010 12:35 PM
stevedohc16v
Mar 31, 2009 05:06 PM
florent78
Aug 8, 2008 08:49 PM
AJC
Jan 5, 2005 07:43 AM
