Won't run after head gasket replaced.
Old Jun 19, 2018 | 10:05 AM
cossie51's Avatar
cossie51
Default Won't run after head gasket replaced.
Hi a mate has just changed his head gasket on his 2wd sapphire and now it won't run on all 4.
Good spark on cylinders 1 and 4 but very weak on 2 and 3. It has fuel on all 4 cylinders and has had rotor cap and leads replaced but still the same.
Ran on 4 cylinders before changing gasket.
Any ideas what this could be ? Totally standard engine with no upgraded parts.
Old Jun 19, 2018 | 10:27 AM
bigdel's Avatar
bigdel
Check the gap on the sensor in the distributor
Check your engine earth as well, make sure you have good contact
Old Jun 19, 2018 | 10:42 AM
Caddyshack's Avatar
Caddyshack
Also check the hall sensor is plugged in tightly in the distributor if that has been messed with (mine had worked loose) I have done away with it all now and gone coil on plug with cam position sensor. change out the plugs and if the fuel is older than 3 months I would add new.
Old Jun 19, 2018 | 01:38 PM
The Youth.'s Avatar
The Youth.
put it to TDC and recheck rotor arm position
also recheck the cap to leads connections particularly on the 2 affected cylinders,
Steve
1374lee
May 26, 2014 10:04 AM
WTF?!
Sep 8, 2013 10:38 AM
Sven
Jun 22, 2007 01:36 PM
Sven
Jun 16, 2007 07:40 PM
Fudgey
May 5, 2005 12:57 PM
