Ford transit - no fuel to injectors with manual priming pump
Old Jun 15, 2018 | 06:46 PM
nextural's Avatar
nextural
Default Ford transit - no fuel to injectors with manual priming pump
Hi all,
Got a Ford Transit, 2001 Mk6, 2.4 litre, TDDI which is suffering from a lack of fuel. I'm not getting fuel to my injectors even with a manual priming pump and manually cranking it, it's as if the fuel can't get beyond the pump.
When manually turning the crank with a wrench and pumping with a manual priming pump I don't get any fuel to the injectors. I've tried pumping directly into the fuel pump inlet pipe and I know there's no air in the system because the pump bulb goes hard. As per Haynes manual, I've tried turning the crank 180 degrees, and in 5 degree increments, but at no point does fuel come out of the injectors like the manual says it should.
Strangely, when turning the engine with the key I get fuel to injector 1 only. Any ideas?
Engine was running fine on idle but cutting out under load - fuel supply issue.
Changed the injectors but no difference.
Found the tank inlet on the fuel filter head was blocked so replaced the fuel filter head and fuel filter.
Using a manual priming pump I get fuel running fine from the tank, through the filter and to the pump but it doesn't seem to get any further.
Cheers,
Michael
Dean Saff
Feb 5, 2007 08:52 AM
cdc
Jul 18, 2006 09:33 AM
sime73
Jun 11, 2006 04:08 PM
Ryan
May 12, 2005 05:24 PM
