Problem with aftermarket rpm gauge
Old Jun 15, 2018 | 06:46 PM
s2erst's Avatar
s2erst
Default Problem with aftermarket rpm gauge
I have got a s2 rs turbo with zetec turbo so running coilpack. I just fitted a aftermarket rpm gauge and I've switched it 4 cylinder on back of gauge and I've run the signal wire to the one on the wires on plug on coilpack. The problem ice got is when car is started the revs start at 8k any ideas why thanks
Old Jun 15, 2018 | 06:49 PM
Caddyshack's Avatar
Caddyshack
If you rev it does it move? If so it may need a resistor. If it doesn’t move then I suspect you have connected it to a constant positive.
Can you not ask the manufacturer tech dept?
Old Jun 15, 2018 | 07:35 PM
s2erst's Avatar
s2erst
Yes it does rev higher. Aftermarket rpm gauges shouldn't need a resister
Old Jun 15, 2018 | 10:04 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
If you're on a coil pack, the gauge probably need switching to 2 cylinder as it will be running wasted spark and triggering the coil once per crank revolution rather than once per two revolutions.
Old Jun 15, 2018 | 10:16 PM
s2erst's Avatar
s2erst
Ok I will turn it to 2 cylinder and see if that works. It won't make any difference that I've wired 3 other gauge together using the same live feeds and earth will it
Old Jun 16, 2018 | 08:54 AM
Caddyshack's Avatar
Caddyshack
That depends on the signal that it gets.
I had a webcon ecu on a zetec in a kit car and I had to use a resistor to make the aftermarket gauge stop reading half revs.
Old Jun 16, 2018 | 01:42 PM
s2erst's Avatar
s2erst
I've heard about it when it reads half but mine is at 8k
rog
Jun 10, 2009 06:38 PM
rickbartlett
May 19, 2009 06:18 AM
rickbartlett
38
Mar 28, 2009 04:13 PM
scoooby slayer
38
Sep 4, 2008 10:03 PM
