Cosworth aux pulley ??
Old Jun 9, 2018 | 01:22 PM
cossie daz's Avatar
cossie daz
Default Cosworth aux pulley ??
Hi all ,
Hope you can help .
Are the Sierra cosworth cam pulleys and aux pulley the same size where they go onto the cams and aux shalf .
What I mean by this is the centre bore size .
I’m trying to fit the aux pulley onto the shalf but seems aux shalf to wide to push pulley on .
Want to know if different size cause if they are I might be trying to fit a cam pulley onto the aux .
Many thanks in advance
Old Jun 9, 2018 | 03:05 PM
The Youth.'s Avatar
The Youth.
there deffo the same size, give it a clean with some emery paper
Steve
Old Jun 9, 2018 | 03:27 PM
james kiely's Avatar
james kiely
i had the same problem .aux is different bore as far as i know
Old Jun 9, 2018 | 06:22 PM
costina's Avatar
costina
Live long and prosper!!
Cams 24mm
Aux 26mm
Old Jun 9, 2018 | 06:25 PM
costina's Avatar
costina
I might have a spare if you need one.
Old Jun 10, 2018 | 03:23 AM
cossie daz's Avatar
cossie daz
Thanks costina but I’ve located one now .
Thanks anyway
Old Jun 10, 2018 | 05:57 AM
The Youth.'s Avatar
The Youth.
Originally Posted by costina
Cams 24mm
Aux 26mm
that did suprise me i'm sure I've swapped them over before, but I checked last night and yes it's different!
Steve
Franco
12
May 23, 2009 09:05 AM
wskxd14
May 23, 2008 07:51 AM
Terry Tibbs
Aug 15, 2006 10:37 PM
yogi
Nov 8, 2004 02:28 PM
