Sierra - ATE accumulator brake system HELP!
Old May 30, 2018 | 01:29 PM
robinball's Avatar
robinball
Default Sierra - ATE accumulator brake system HELP!
Hi,
Just wondering if anyone has any ideas. I have a Sierra which had ABS, I've removed the ABS unit, wheel speed sensors and replaced all the metal and rubber lines for braided lines through the whole car (see photos below)
Obviously being an ABS model originally it's got the ATE accumulator type master cylinder (see offending unit below)
Since I've done this the front brake work fin, the rears however literally don't do anything. Even bleeding them way a pain, they gravity bleed but when the pedal is depressed the fluid doesn't move any quicker. Initally I though it was the OE bias valve so I bypassed this last night and it's still the same. Before I go condemning brake master and trying to fit a normal non-ABS Sierra traditional master and servo setup, does anyone have any ideas why there would be no pressure to the rear brakes and but the front work fine? In addition the pedal does feel a bit funny, but it was several years since I last drove the car standard so I'm not 100% if it's not right.
Anyway thanks in advance Robin
Old May 30, 2018 | 01:43 PM
Caddyshack's Avatar
Caddyshack
There is a procedure for bleeding the rears, I think you need to turn the key one turn to run up the abs pressure pump.
Old May 30, 2018 | 01:46 PM
Caddyshack's Avatar
Caddyshack
Have a read of this https://passionford.com/forum/genera...-bleeding.html
Old Apr 28, 2026 | 05:12 PM
cattlerustler's Avatar
cattlerustler
Originally Posted by robinball
Hi,
Attachment 183406
Attachment 183407
Attachment 183408
Attachment 183409
Attachment 183410
I've sent you a direct message I am trying to do a similar setup and I'm struggling with which brake line goes where
RalliArttu
63
Mar 3, 2020 07:39 AM
HmmDK
34
Aug 23, 2018 03:48 PM
rwd_fiesta
65
Jan 22, 2017 09:32 AM
5tox
Jan 17, 2011 08:29 PM
Rob_DOHC
Nov 7, 2010 03:36 PM
