2wd boot badge position?
Old May 26, 2018 | 10:16 AM
tosh's Avatar
tosh
Default 2wd boot badge position?
I had a printout of the boot badge positioning which I copied from somewhere but as usual I can’t find it, it was copied from a workshop manual I think!
Has any one got it or can point me in the right direction. Cheers
Old May 26, 2018 | 08:07 PM
4x4kiwi's Avatar
4x4kiwi
Probably of no use for a 2wd but here is a link to the positions of the badges on my 4x4
David
https://passionford.com/forum/ford-s...-position.html
Old May 26, 2018 | 09:51 PM
bigdel's Avatar
bigdel
Old May 26, 2018 | 09:54 PM
cossynut2's Avatar
cossynut2
10 Year Member
If you have a friend with a Saff the same as yours just take some photos and measurements so you know where to position yours. Photo of my boot 2wd Saff.
Does this help?
Old May 27, 2018 | 06:44 PM
4x4kiwi's Avatar
4x4kiwi
Looking at the picture of cossynut2's car and comparing it with the picture of my 4x4 in the other thread, looks like the spacing may be the same on both cars, just different badges. David
Old May 27, 2018 | 07:53 PM
tosh's Avatar
tosh
Thanks for all the replies lads and apologies for just leaving it running without my input,
I knew I had the original spacing details somewhere, found them on the old pc which hasn’t been on for 6 months.
I can’t make out a couple of the measurements so hopefully someone can double check them when they get time
Old May 28, 2018 | 05:14 PM
cossynut2's Avatar
cossynut2
10 Year Member
tosh. looks to me that you only need 4 basic measurements. COSWORTH badge 27mm from bottom of boot lid to bottom of badge. Sierra RS badge 54mm from bottom of boot lid to bottom of badge. 54mm from side of boot lid to start of both badges, 5 mm gap between them. put masking tape on boot lid to use as templates and you should be ok.
Old May 28, 2018 | 09:00 PM
tosh's Avatar
tosh
Looks like the two bottom measurements to the lower edge of the Cosworth badge are not the same! 27.0 on left and what looks like 28.0 on the right, but I don’t think anyone will notice if it’s 1mm out lol.
Thanks again for your info gents, I will also use the dimm’s that 4x4kiwi posted for the oval badge.
rs,s1ste
Jun 19, 2017 07:23 PM
zedtechs
Jul 8, 2010 07:25 PM
Black XR3i
Oct 26, 2006 11:49 AM
mikee_rs
Jul 29, 2006 12:09 PM
