YB Spot pointer and woodruff key alinement
just coming back on Cossy YB cam timing spotted.
Notice if builds vary,ie Deck and head higts,or in my case Wiseco pistons up 0.020 th,on a WRC 1.3mm head gasket. On Std pulleys.
Research via Kent cam"s is to ignore that,and Dial + DTI the peak on cam lift @ as with Std cams 110*degres.IN MY CASE
Think about it, as head up and down with machining,block or head, plus what ever head gasket you use,will knock standard way out.
Though let you know troops,as no rely to pervious thread.
off to retime cams ! ALB Pete.
pete241
May 17, 2018 07:42 PM
SPADGE
Apr 4, 2006 07:26 PM
