MK1 Focus ST170 Clutch Advice
Old May 16, 2018 | 04:42 AM
rsg26's Avatar
rsg26
Default MK1 Focus ST170 Clutch Advice
Hey guys
I have recently bought a 2004 Ford Focus ST170 that is in need of a new clutch and flywheel. Its an 05/2004 Model. After some research I have found a LUK 07175 clutch kit which includes the flywheel. These seem to be a lot cheaper than other options. My issue is it generally states these are for 03/2004 and older models.
I have found a Sach clutch kit but it double the price. The specs seems to be identical:
https://www.ebay.com/itm/2002-2004-F...IAAOSwIhtanKY0
https://www.ebay.com/itm/NEW-Clutch-...5.c10#viTabs_0
Does anyone know if I can use the LUK 07175 on my 05/2004 Model, and what the differences might be with the clutch?
Any help hugely appreciated.
Old May 16, 2018 | 08:47 AM
big_wasa's Avatar
big_wasa
They changed the diameter of the clutch and fly' and upped it from 230mm to 240mm.
As a full package they are interchangeable. If the car is a keeper look at the ttv/ helix setup. If your tuning it, the same.
Old May 16, 2018 | 09:43 AM
costina's Avatar
costina
Live long and prosper!!
As above I just fitted a luk clutch 240mm to mine cost 446 on eBay.
Its a pig of a job and you will need a 22mm clutch alignment tool and a fitting tool to compress pressure plate before tighening...
IF YOU DON'T YOU WILL HAVE NO CLUTCH.....
Spray all suspension pinch bolts with WD as they usually seize along with the drive shaft splines.
Good luck or better still pay a garage to do it I would next time and I am in the trade....
Old May 16, 2018 | 01:48 PM
rsg26's Avatar
rsg26
Default What model clutch was it?
What year is your st170? Which luk clutch did you get?
Old May 16, 2018 | 02:40 PM
costina's Avatar
costina
Ebay seller Parts2clear.
rsg26
Apr 24, 2018 06:11 AM
philg12
Aug 28, 2014 06:30 PM
ricky_2006
Sep 21, 2010 04:55 PM
Rob Anderson
Ford Focus RS
Apr 15, 2010 07:46 PM
gazloveslou
Feb 21, 2009 08:57 PM
