RBT Front imbalance 41% Mondeo 2.0 TDCi 2010
Old Apr 28, 2018 | 09:27 AM
DanFraser's Avatar
DanFraser
Default RBT Front imbalance 41% Mondeo 2.0 TDCi 2010
Hi,
so Max has just failed on brake imbalance (and a number plate light).
The tester said the offside brake was engaging much later than the near side with less force. Reading around I should be feeling a heavy pull to one side whilst braking but I don’t, at all!
What would this most likely be? Sliding pins?
Old Apr 28, 2018 | 12:08 PM
Adder's Avatar
Adder
If it were me I would be squeezing the Pistons back and see if you pull the calliper in and out. This should prove the sliders are free and should be able to check the pads are free too. Make sure you get a bit of heat into your brakes before it goes on the brake rollers too. If your tester is ok he will check before he logs it on to check. If the prob persists I have swaped the pads from left to right in the past and had good results. This is assuming your discs are not to badly grooved/worn. Hope this helps
Old Apr 28, 2018 | 12:21 PM
GVK.'s Avatar
GVK.
Surely you would feel a 41% imbalance on the road!
Old Apr 28, 2018 | 04:10 PM
Adder's Avatar
Adder
I hav'nt tbh, I've done rbt on many many occasions. The rollers have measured high brake imbalance some times well over 50%. I've taken the car down the road to warm the brakes and thought well I can't feel a bloody thing ! Warming the brakes can help them.
t7craig
Sep 4, 2014 10:27 PM
Paul_RS
13
Sep 4, 2013 03:27 PM
Robmatheson
Music & Car Audio Chat
Nov 9, 2012 07:07 PM
RS500
12
May 22, 2010 10:28 PM
AL_Capino
Shows & Track Days
12
Mar 13, 2010 01:30 AM
