Water seals T34
Old Apr 27, 2018 | 09:01 PM
plynchy's Avatar
plynchy
Default Water seals T34
The only leak I have on the newly installed motor is from the water return on the turbo. I fitted new aluminium sealing washers but unable to achieve a seal. All the sealing faces look good.
Anyone used copper in place of aluminium, or some kind of sealing compound?
Old Apr 29, 2018 | 09:49 AM
The Crocodile Hunter's Avatar
I would try some copper washers
Old Apr 29, 2018 | 10:37 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Dowty washers are perfect
Old Apr 29, 2018 | 03:17 PM
plynchy's Avatar
plynchy
Are they?
Thought the rubber seals wouldn't last 2 minutes with the heat?
Old Apr 29, 2018 | 03:18 PM
ajamesc's Avatar
ajamesc
Na there fine
Old Apr 30, 2018 | 12:56 AM
Adam-M's Avatar
Adam-M
Originally Posted by plynchy
Are they?
You can buy them with viton high temp seals
rsguy
Apr 21, 2013 07:30 PM
lukeyboy
Ford Escort RS Cosworth
Feb 25, 2012 10:41 AM
B1G_RST
Dec 29, 2007 11:42 AM
CosRush
Jun 13, 2007 05:23 PM
Combi_Chris
Mar 2, 2006 10:12 AM
