Focus mk2 st knuckles Pre and facelift
Old Apr 27, 2018 | 06:11 PM
carbon1993's Avatar
carbon1993
Default Focus mk2 st knuckles Pre and facelift
Went with the focus for an aligment. Too bad somithing is bend. All values are good but camber on the right side is way off. They said the knuckle is bend. I kind off doubt that. I think the damper is bend as the wheel also stands abit to the rear.
tho i want to start with a knickle because of the cost. Do mk2 facelift knuckles fit?
Old Apr 27, 2018 | 07:38 PM
studabear's Avatar
studabear
Not sure if they are the same, but like you I also think the damper is more likely the issue.
Old Apr 27, 2018 | 10:16 PM
RichieST's Avatar
RichieST
Lower arm possibly if its had a knock. Aren't the knuckles cast? I would imagine they would crack rather than bend.
Old Apr 28, 2018 | 08:08 AM
carbon1993's Avatar
carbon1993
It isn't the lower arm as it will change the caster and kpi.
Can get a knuckle for 100euro. Think 2 new dampers will cost alot more. Would be shite to buy expensive new dampers and the problem would be still in the knuckles. Rather spend 100 euro for nothing than 400 or something.
bertyboo
Fiesta ST
Apr 13, 2016 05:19 PM
gwvanduin
Ford Mondeo Including ST
Dec 1, 2013 10:49 AM
Crossy
Fiesta ST
Jun 3, 2013 09:18 AM
