Cambelt cover query
Old Apr 8, 2018 | 07:26 PM
domink_goodfellow's Avatar
domink_goodfellow
Default Cambelt cover query
Hi I’m after a bit of info please as have searched google high & low & cannot find the answers I’m looking for.
I have recently purchased a 4x4 cambelt cover as mine never came with one, so I have the fixing posts which sit on the top of the cam cover & the 3 upper fixings but I can see there are 3 other holes further down the cover that need fixings. Does anyone know what they are & where I can get some from.
Thanks
Dom
Old Apr 10, 2018 | 04:11 PM
The Youth.'s Avatar
The Youth.
there is 4 fixings in total on a 4x4 cover, 2 at the top on the posts, 1 on a post in between the cambelt pulleys and 1 on the lower right of the bottom pulley, this had from the factory a smaller 8mm flanged head bolt and a spacer washer to correctly position the cover away from the bottom pulley.
Steve
Old Apr 10, 2018 | 06:30 PM
domink_goodfellow
Steve
Thats great thanks Steve, I have the top/middle 3 but will need to get the one then that goes on the lower right. Any ideas whether I could locate this?
fraser9764
May 30, 2011 09:05 PM
Steve Escos
Apr 4, 2010 12:16 PM
Andreas
Aug 26, 2004 02:27 PM
