Weak interior air vent flow
Hello fellow ford lovers,
I drive a beauty of a ford focus mk1 1.8 TDDI estate, but I have an issue with the 'power' that interior air vents blow in to the car, specifically the air vents that are closest to the driver and passenger windows!
Does anyone know what the issue could be? I've had a quick search online but can't seem to find any reasonable explanation to what it could be.
Any help or advice would be greatly appreciated.
Cheers guys and gals!
Hi there,
Yes the fan works on all speeds and temperatures. The two centre fans work as they should, but its mainly the side fans closest to the front driver and passenger doors that give little to no air out. If i put my hand to it you can feel a faint air flow.
Thanks for the reply.
Fezman1
31
Apr 13, 2013 06:52 AM
