Wheels and Tyres Wheels and Tyres for all Ford's
mk2 focus RS rims on mk2 ST
Old Mar 30, 2018 | 08:06 PM
carbon1993's Avatar
carbon1993
Default mk2 focus RS rims on mk2 ST
Hello,
Anyone fitted focus RS rims on their ST? Bought RS rims for my ST but they barely fit.
The car is completly stock suspension wise.
So they need some spacers. But does annyone knows which spacers to run?
Got 1mm space at the front between the shock and wheel.
At the rear they rub the shock cover and inner wheel arch tub.
Did some trial fitting at the front i need 3mm spacers and 5mm for the rear to clear.
The hub centres that stick in the rim are 1.1mm. The rims have a skewed side of 3mm at the centre bore of the rim.
If i stick some 5mm spacers on it the hub will stick 1.5mm in the centrebore to centre it. Seems like a bit dangerous...
Anyone experience or tips to fit these rims safely?
Old Mar 30, 2018 | 08:42 PM
smiley's Avatar
smiley
Hi my mate has a unit next to a guy that has a lot of the st owners club boys come by daily a good few st's running rs rims the guy that owns the unit runs one on these also if you don't get the info you need I will ask him for you when I next see him possibly tomorow
Old Mar 30, 2018 | 09:06 PM
carbon1993's Avatar
carbon1993
That would be great! would really appreciate that !!!
Old Mar 30, 2018 | 10:54 PM
smiley's Avatar
smiley
No problem mate
Old Mar 31, 2018 | 07:14 AM
RichieST's Avatar
RichieST
Yes you will need spacers to cure clearance issues. I used 15mm eibach hubcentric spacers on mine.
Old Mar 31, 2018 | 09:53 AM
smiley's Avatar
smiley
Just seen him as above 15mm ideally 20mm all round he said not to use denso they snap use eibach or h&r racing
Old Apr 2, 2018 | 07:41 PM
STeve's Avatar
Super Moderator
recently ditched my frs rims as did not like using spacers and bought aftermarket with a et of 40 instead
Old Apr 5, 2018 | 09:36 PM
carbon1993's Avatar
carbon1993
Thanks for the reply's! Which spacers did you use. Ones with studs in the spacers or studless spacers? Do you need to cut the studs when fitting 15 or 20mm spacers? or did you replace the stock studs with longer ones?
Old Apr 7, 2018 | 06:15 PM
STeve's Avatar
Super Moderator
you need hubcentric if going spacer route and always chose quality like eibach or h&r, slip over spacers are pure rubbish
Old Apr 19, 2018 | 08:46 PM
carbon1993's Avatar
carbon1993
got some H&R spacers on it 2cm all round. slightlty rubbing on the right front. Hope it get's fixed with a litle alignment.
Thanks for the help!
Old Apr 20, 2018 | 08:00 AM
STeve's Avatar
Super Moderator
normally fit 12/15mm on the front for this reason as 20 is a tad wide
Stu @ Claims Care Centre
May 18, 2009 10:27 AM
mercury grey minter
28
Nov 20, 2007 05:53 AM
