Rear brake compensators
Old Mar 27, 2018 | 06:08 PM
RS89's Avatar
RS89
Default Rear brake compensators
Hi. I’ve stripped the rear underside of my S2 for a proper tidy up, powder coating most things and replaceing the worn stuff, I’ve managed to source most thing...clips, hoses etc but I’m struggling to find new compensators, anyone know if they can be blasted without damage? Or any other ideas..I want to keep the set up as the car is totally standard.
Ill post up a thread of the progress soon, usual thing, I started with thinking I’ll clean it up a bit but it got out of control. Cheers
Old Mar 27, 2018 | 10:25 PM
ger80's Avatar
ger80
If I were you, I'd take them to a blasting specialist, and they will know what to do. They should be fine blasting with the right media. Just once they're protected on the inside would be very important.
Old May 12, 2018 | 07:11 AM
Karlos G's Avatar
Karlos G
Balls Deep!
If you blast them by hand and make sure you don't get any blast media in then you probably could, if not they are only small so just rub them down by hand before painting.
marc_gti
Apr 16, 2013 07:52 PM
dave_s2_rst
Nov 18, 2010 01:23 PM
bennyboy
Fiesta RS1800/RS Turbo
Jun 21, 2007 09:35 PM
jonesymk2
May 16, 2005 06:03 PM
