Fiesta ST This forum is for discussion of all things pertaining to the Ford Fiesta ST Range of cars.
How to turbo or supercharge a fiesta st150
Old Mar 15, 2018 | 06:24 AM
150St06's Avatar
150St06
Default How to turbo or supercharge a fiesta st150
So I brought a st150 a few months back and now I want to do something different that not many people have done.
Whats better supercharging or turbocharging?
how much will it cost roughly to convert my car?
What will I need to change to make my car compatable
any help appreciated
Old Mar 15, 2018 | 07:27 AM
Caddyshack's Avatar
Caddyshack
10 Year Member
To do properly I bet you would get through Ł4k-Ł5k if you cannot do much of the work yourself.
You will need someone good with that ECU or aftermarket, speak to Mark Shead at MAD as I think he can map the ford modern stuff or Stu at MSD. You will need to mount an intercooler or charge cooler, fabricate a down pipe, probably sort an oil feed and drain.
The chassis and brakes will need attention if you go big power.
Things like injectors, boost pipes, heat shields, fuel system all need to be considered and costed.
Personally I would buy a different car.
Old Mar 15, 2018 | 03:01 PM
As_Bo's Avatar
As_Bo
Jamsport seem to be one to ask.
https://passionford.com/forum/fiesta...150-turbo.html
This might help.
https://www.sico-developments.co.uk/...-fiesta-mk6-st
Old Mar 15, 2018 | 03:09 PM
150St06's Avatar
150St06
Ok thankyou! I will have a look see what others have said!
fastfezzy G
42
Apr 2, 2015 06:04 PM
mondee_al
Dec 24, 2008 12:13 PM
Big Gib si 16v
Fiesta RS1800/RS Turbo
Oct 7, 2005 10:14 AM
Adam_BlackRS
Jun 29, 2005 05:17 PM
JimmyFlo
Mar 24, 2005 06:33 PM
