Ford Escort Mk1. T5 Sierra box
Old Mar 7, 2018 | 08:18 AM
RTP1's Avatar
RTP1
Default Ford Escort Mk1. T5 Sierra box
I would like to fit a T5 gearbox to my Mk1 Escort as we are also installing a BDA engine.
Does anyone know if this is this a relatively straightforward exercise?
Old Mar 7, 2018 | 12:17 PM
costina's Avatar
costina
Live long and prosper!!
If your car was an auto from factory then yes if not you will have to fit another tunnel from a Sierra or you can get pre formed tunnels from Rally Design, Escort TEC, Motorsport tools to name a few.
Also check out turbosport.co.uk which is mainly escort based forum.
Old Mar 7, 2018 | 03:07 PM
turbo m's Avatar
turbo m
A t9 would be eaiser with uprated internals as you can use the std tunnel and just a modded gearbox crossmember.
Depends if you can get a t9 in nz???
Old Mar 7, 2018 | 04:28 PM
Ronnie-rsmk1's Avatar
Ronnie-rsmk1
hi, im pretty much going to be doing the same..though im thinking of going the pinto 200 block with dohc head route . Im collecting panels and bits and pieces at moment. I'd like to hear how you get on...Ronnie
paulshears
Sep 2, 2013 11:30 PM
Ollie MK5 Turbo
33
Sep 16, 2011 07:10 AM
rosie
Ford Classics & Vintage
Aug 3, 2006 07:18 PM
capri-rs
13
Dec 13, 2004 09:43 PM
