Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
2002 TDCI slow to fire up
Old Feb 26, 2018 | 04:42 PM
splash550's Avatar
splash550
Default 2002 TDCI slow to fire up
When left overnight or for long periods, our 2002 Focus 1.8 TDCI turns over for 10 seconds before starting/firing.
It is then fine for the rest of the day and usually starts within 2 or 3 seconds.
There are no fault codes, no lights on dash, battery is brand new, it has had glow plugs within the last 6 months, injectors have been 'leak tested' and are fine. Car has done approx 104,000 miles.
Any ideas please - it's driving us mad!?
Old Feb 26, 2018 | 06:56 PM
RichieST's Avatar
RichieST
You may have a very small air leak in the fuel system causing the fuel to drain back to the tank. I think there is also a non return valve in the system that may also have failed.
Old Feb 26, 2018 | 07:16 PM
splash550's Avatar
splash550
That's exactly how I would describe it - it seems like the fuel is draining back to the tank. I'll take a look for leaks. Thanks.
Old Mar 3, 2018 | 03:03 PM
uruk hai's Avatar
uruk hai
Could be you starter motor's getting tired, mine had to be changed at 5 years old. First start of the day would be laboured and the engine shook quite a bit, after that it would be fine, changed the motor and Roberts your mothers brother !
xr2john
14
Dec 22, 2016 08:51 PM
Mr RS500
PassionFord FAQs
Apr 13, 2010 08:24 PM
rapidcossie
22
Aug 29, 2007 08:37 PM
SPADGE
62
Jun 26, 2006 08:08 AM
moonstone mike
Computers, Consoles and I.T.
Oct 13, 2005 07:53 PM
