Zvh to full zetec
i am looking to change my fully forged 2.1 zvh and build a forged full zetec motor, will me zvh mounts be a straight fit to the zetec ? And will my go tech each be ok to run a full zetec turbo ? Cheers
I'm not sure if black top and silver top mounting points on the block differ but if the ZVH was silvertop and the ZT is silvertop it should be fine and like wise if blacktop.
I cant think why your gotech wouldn't work, might need a bit of rewiring depending if you change anything on the inlet side of things and then obviously the mapping will need adjusting.
NATH-RSZT
Nov 20, 2007 07:45 PM
