my 3dr restoration project (4/10/05 UPDATE)
well here goes
these photo's are the day she arrived home and before i got her into the workshop to be stripped down to a shell
nice seat
as you can see a bit of work needed.....and i will post up pics as i do work
Pugo
nice seat
Pugo
did anybody laugh at the reyland escos with a towbar
(but it is coming off)
inner wing looks worse in real life
but it is only metal and is the only real nightmare on the car
right time for an update, i have welded all new metal into the inner wing
stripped everything off of it, started on the engine bay first as this is where all the grot was
am now about to start underneath.....
still going at it when i find the time, and am starting to source parts now
but i had to drop a few bits on it so i could visualise it and to keep the spirit up
look at this badboy
Pugo
look at this badboy
Pugo
Right, i have been a busy boy and got stuck in the last couple of weeks, all the underneath i sand blasted back to metal, i then started stone chipping it all and finished off the engine bay, just needs nibbing off and a top coat in the morning and i can start putting the engine bay back togethor
So here is the floor in stonechip awaiting a coat of the diamond white
Offside rear wheelarch in stonechip with a coat of paint on it
Engine bay now in primer and all ready for a coat of paint
that mullared inner wing all now replaced with new metal and in primer
that rotten innerwing now in a base coat of diamond white...looking shiney
The other side just had to match
here is the engine bay in a base coat of diamond white nearly dry awaiting a quick nib then a top coat in the morning
here is another of the engine bay with a lamp on it trying to keep the moisture off whilst it dries
so as you can see it might be taking forever but i am slowly getting there
tomorrow i am going to finish of the stone chip and stick some diamond white on the whole of the floor...
i am going to start prepping the inside of the boot and then its trim up time
will add some more pics as i get nearer the trim stage
Pugo
Pugo
nice resto mate i did a moonstone gone in same place on inner wing once. thing is i bought car with engine in boot. put engine in and bottom end was gone , but it was "only in the boot to do the wing mate" keep the pics coming youth and save another legend!!!
okay.......another update, started to assemble the engine bay and have started on the trim as well
this is it for a month as i am going to be busy at work
can't finish the brakes till i locate a 3dr abs bracket
Pugo
Pugo
lookin good fella!!
whish i had time money and space to do this to my cars.....one day maybe.....
what paint are you using? 2 pack or cans? compressor powered paint guns? looks good
when you say 'nib off' - are you talkin about knockin the peel texture out of the base coat before laquering? are are you just using base coat?
timbo
timbo
Originally Posted by FingerZ!
lookin good fella!!
timbo
timbo
HTH
nice one mate
lookin good!
have to give us a look maybe one day soon
will try n get a bit more done on the saph to show ya but to be honest im a bit skint at the mo - no job
keep it up mate!
lookin good!
keep it up mate!
just striped it back to a bear shell again today
its ready to go to the sprayers next week where its getting sprayed inside and out
any chance you could email the pics in this thread as they are not working now
cheers rob
rob_c_79@msn.com
cheers rob
rob_c_79@msn.com
