Bulkhead sound deadening material, what to use?
Old Jan 26, 2018 | 03:41 PM
rog's Avatar
rog
Default Bulkhead sound deadening material, what to use?
After painting the shell I am rebuilding a saph and the old stuff is wrecked, just wondered what people have used?
Old Jan 26, 2018 | 04:01 PM
smiley's Avatar
smiley
Ive seen alot say dynamat mate
Old Jan 26, 2018 | 04:20 PM
Caddyshack's Avatar
Caddyshack
Dynamat dulls the panel which is great but you should then get a sticky backed decoupling layer which is either foam rubber or something like the original fluffy stuff.
Old Jan 26, 2018 | 04:54 PM
rog's Avatar
rog
Is that stuff pretty heat resistant, I always thought it was just for ICE builds and using in doors and general stuff inside the car? I’m pretty paranoid of stuff going on fire etc It’s for the engine bay, not the stuff inside the car, sorry I didn’t say in my original post.
Old Jan 26, 2018 | 05:00 PM
Mark V8's Avatar
Mark V8
https://www.ebay.co.uk/itm/Sierra-Co...53.m1438.l2649
Old Jan 30, 2018 | 08:41 AM
rog's Avatar
rog
Thanks for the suggestions, I wanted to go for silver or gold so I decided to try some of this. Wasn’t sure on the Dynamat spec, I couldn’t seem to find a temperature rating listed for it, from memory I think it may be the dynaliner stuff I was looking at.
From general research this stuff seems to fall into 3 categories, no temp rating, 200c and then 1000c, there’s doesn’t appear to be an in between
https://www.carinsulation.co.uk/prod...van-insulation
Old Jan 30, 2018 | 10:40 AM
Caddyshack's Avatar
Caddyshack
That is pretty cheap compared to some Cossie taxed stuff
Jack and the Beanstalk
Jan 23, 2018 12:43 PM
