Sound proofing / Sound Deadening / Sound Dampening a Sapph
Old Jan 23, 2018 | 12:29 PM
Jack and the Beanstalk's Avatar
Default Sound proofing / Sound Deadening / Sound Dampening a Sapph
Good Day All
Is there info or a post regarding best methods for sound deadening or sound proofing Sierra / sapphires?
Sound Deadening Material
I have a bare shell that's been newly painted and want to install new sound dampening / deadening materials
I've removed all the old crusty material before I had it painted and want to apply some new materials
I've sourced a supplier locally that can assist me with my requirements
Factory Underlay
I've kept the factory underlay and carpeting. The factory underlay is in a bit of a state. Is there a way to repair this underlay (black hard liner with the soft material underneath) some parts of the underlay are cracking, torn and breaking. Is there a specific tape or patch I could use to repair this?
What are some of the installs you may have done could assist me to do this correctly?
Old Jan 23, 2018 | 12:43 PM
Caddyshack's Avatar
Caddyshack
You need a sticky layer like Dynamat ideally. There are cheaper brands though (do not use roofing flashing) Then you have a "decoupling" layer like the under lay or a foam and then your carpet. There are some nice rubber sticky products too....the more you do the better but layers are what you need.
jon22
Ford XR Parts For Sale
Jun 24, 2011 07:59 PM
NUTTIN RILLA
12
Jul 5, 2007 11:51 AM
Iain Mac
Mar 31, 2006 03:49 PM
S1rst
Nov 5, 2005 04:27 PM
Robin
May 28, 2005 10:30 PM
