People's thoughts on which cooler I should use
Old Jan 4, 2018 | 03:01 PM
jonfoc's Avatar
jonfoc
Default People's thoughts on which cooler I should use
Ive got 2 options. Radtec WRC or pro alloy RS500 style. What's people's thoughts? It's going on my focus rs mk1 track car.
Old Jan 4, 2018 | 03:34 PM
Caddyshack's Avatar
Caddyshack
My car mapped at 469 bhp on the RS 500 one I sent you, Mark said the temps were limiting how much further he wanted to go with the engine but if you are going to be under 400 I bet you will be fine on that.
Old Jan 4, 2018 | 03:36 PM
jonfoc's Avatar
jonfoc
This is my problem Toby. I'm looking to be around 500.
Old Jan 4, 2018 | 04:01 PM
Caddyshack's Avatar
Caddyshack
What sort of boost will it be running to hit that sort of power?
500 on a track car is a lot of heat to deal with
Old Jan 4, 2018 | 05:10 PM
jonfoc's Avatar
jonfoc
2 bar mate
Old Jan 4, 2018 | 05:38 PM
Caddyshack's Avatar
Caddyshack
I wonder if you will be ok as mine was about 2.2 bar and was 50 degrees inlet on the rollers in summer, it seems to be 20-30 but sometimes over on my 100mm airtec one.
Old Jan 4, 2018 | 05:43 PM
jonfoc's Avatar
jonfoc
If it’s on the limit mate I might have to look elsewhere. I wonder what spec-r can offer
Old Jan 4, 2018 | 06:12 PM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
Pro alloy do a larger core one for escort cosworth used on reyland cosworth I think that's good for 650 bhp . Think it's a 65mm core . Pro alloy are the best fabricated and well made intercooler s I've seen personally.
Cheers paul
Old Jan 4, 2018 | 06:20 PM
zetaboostboy522bhp
No sorry it's the 63mm core but used on many cars running above 600 bhp and Ł459 ain't bad at all.
Cheers paul
Old Jan 4, 2018 | 06:21 PM
jonfoc's Avatar
jonfoc
Thanks for the input Paul. That is a cheap price
Old Jan 4, 2018 | 06:59 PM
Caddyshack's Avatar
Caddyshack
I think spec r would want the car to do a bespoke one but if standard escort one fits then you would be looking at Ł1200 for one of the best but not sure how long to build so maybe the pro alloy one is the way to go?
Old Jan 4, 2018 | 07:05 PM
zetaboostboy522bhp
You could also try jimbo at alloy racing tabs , I know he got a load of turbo diesel lorry intercooler cores and they where big and could easily do 650 bhp + so he could custom build one for you , or buy a garret core or similar and get someone to knock the end tanks up.
Old Jan 4, 2018 | 07:43 PM
jonfoc's Avatar
jonfoc
Using jimbo yes, I'd use him in a heart beat. Using a diesel intercooler I'm not so sure. I'd want to know a make and efficiency rating.
Old Jan 4, 2018 | 07:57 PM
Rsmat's Avatar
Rsmat
Can't mark make you one with a Garret core mate ?
Old Jan 4, 2018 | 08:23 PM
jonfoc's Avatar
jonfoc
Probably but he’s a busy man. Also where would I source a Garrett core I’ve emailed Garrett but had no reply
Old Jan 4, 2018 | 08:25 PM
Rsmat's Avatar
Rsmat
I havnt a clue I'm only going on the back of how good they are doing I'm clueless on availability.
Old Jan 4, 2018 | 08:29 PM
james kiely's Avatar
james kiely
just had a look jon and this came up
http://www.atpturbo.com/mm5/merchant...egory_Code=INT
Old Jan 4, 2018 | 08:32 PM
Caddyshack's Avatar
Caddyshack
Mark Shead did have a contact I think, maybe call him?
Old Jan 4, 2018 | 08:44 PM
jonfoc's Avatar
jonfoc
Thanks james I’ve seen that site. The postal cost is huge to get one in the country.
Yeah Toby I just might do that
Old Jan 4, 2018 | 08:54 PM
jonfoc's Avatar
jonfoc
To be fair I’m probably over egging the pudding. I’m sure an off the shelf jobbie from spec-r or similar will do.
Old Jan 4, 2018 | 09:01 PM
james kiely
use meth injection as backup jon .
zetaboostboy522bhp
The diesel cores are large cores with large finns for cooling in fact they look like the same size as pro alloy ones when I looked over them . It's not the fact it's for a diesel it's the sizes of the cores and a 650 bhp lorry needs a lot of cooling so if it works on a lorry then it will Defo work on your car . Also when mounting the cooler slightly tilt it forward or backwards around 15 degrees as this really does make the intercooler work a lot better as the cold air is passing over the cores and the fins more efficiently.
Cheers Paul
Old Jan 4, 2018 | 09:05 PM
james kiely
thats a great tip paul
Old Jan 5, 2018 | 06:40 AM
AJC's Avatar
AJC
SpecR top feed?
Old Jan 5, 2018 | 06:43 AM
jonfoc's Avatar
jonfoc
Originally Posted by AJC
SpecR top feed?
That would be nice. Not sure I could make it fit. I’m hoping to get a few replies to email today. If I need to take the car somewhere I will
Old Jan 13, 2018 | 08:22 PM
Caddyshack's Avatar
Caddyshack
I wil, be taking a virtually brand new airtec 100mm off my car soon, it is same as the rs500 one but thicker front to back. It keeps the temps to around 20 deg on my car under load but have seen a bit higher in full summer, it is around 10-15 when weather is like it is now.
Old Jan 13, 2018 | 09:54 PM
jonfoc's Avatar
jonfoc
Pm me what you want for it mate
Old Jan 14, 2018 | 09:14 AM
Caddyshack's Avatar
Caddyshack
I would let you have it for 50%of what I paid for it, it's done about 200 miles on the car.
Old Jan 14, 2018 | 03:35 PM
turbotrev's Avatar
turbotrev
20 deg plus is still a really decent figure, why you changing it Toby?
Cheers Paul
Old Jan 14, 2018 | 03:59 PM
Caddyshack's Avatar
Caddyshack
Cheers Paul
The new engine is 2.2 and a good Ł30k chunk to replace New if it went bang so seeing as there is a spec r cooler that was built to go with it available I thought is was a wise investment, especially if I go bigger turbo or if Mr Shead decides to add a bit more boost.
I think the airtec 100mm is one of the best you can fit before going Garrett core.
Old Jan 14, 2018 | 04:03 PM
turbotrev's Avatar
turbotrev
Gotcha.
So striker with the new engine?
All alloy I’m guessing?
And really is it neigh on 30k for the build!?
That’s mental!
Will be good though
Cheers Paul
Old Jan 14, 2018 | 04:06 PM
Caddyshack's Avatar
Caddyshack
Gotcha.
That’s mental!
Will be good though
Cheers Paul
I have gone for a second hand 2.2 liner block, not all alloy, and yes, the bill was Ł26k inc vat and then the breather and cooler etc was on top and that's with a donor block and head, if you had to source them it would add another Ł4k.
I too was shocked at quite how much all right bits add up to.
Old Jan 14, 2018 | 04:11 PM
turbotrev's Avatar
turbotrev
Holy fuck really!
I’m don’t really want to quiz you about costs but what does that actually include?
ie full engine/manifolds/turbo etc?
And this is a linered 200 block and genuine cosworth head?
What’s the power aim, roughly?
Cheers Paul
Old Jan 14, 2018 | 04:35 PM
Caddyshack's Avatar
Caddyshack
Don't want to ruin Jons thread but the engine was built to over 700 and mapped just over that. The price did not include a brand new block or head, the person paying supplied them iirc, it is a nick wapples head with Harvey Gibbs cams, solid lifters, cam trigger for the ecu pick up(dizzy delete), linered 200 block with Wrc oil systemon remote filter and cooler, oil shirt jets, Wrc breather plus spec r twin cans, 10 long studs...then you go on to arrow stroker crank with rods and Pistons, billet end caps...the list goes on and on. It did include ecu, inlet an turbo etc.
I will only run it 525 on small turbo or 580/600 ish if I go 7670.
Old Jan 14, 2018 | 04:41 PM
turbotrev's Avatar
turbotrev
Yeah fair play, I don’t wanna ruin the op’s thread either.
So it’s already been built and ran etc?
And includes pretty much everything so that’s not too bad then
Cheers Paul
Old Jan 14, 2018 | 04:49 PM
Caddyshack's Avatar
Caddyshack
Cheers Paul
Yes, I has been run in and used a few times.
Old Jan 14, 2018 | 05:09 PM
Rsmat's Avatar
Rsmat
Jon I'm sure crazy cage makes bespoke intercoolers also mate ..maybe a choice .
Old Jan 14, 2018 | 05:19 PM
3doorcozmess's Avatar
3doorcozmess
so your gonna possibly leave it on a 7064 gain 50bhp for 26k ish is that correct?
why would you not just purchase a 200 block and ask mark shead to rebuild it using parts from your current engine at a 3rd of the cost, possibly a quarter.
I don't know mark that well but i reckon he will want the cams gone lol
cheers si
Old Jan 14, 2018 | 05:30 PM
jonfoc's Avatar
jonfoc
I can get one made by my mate Jim at alloy racing fabrications. It's an efficient core I'm after. I've been chatting to the guys at pwr about one of their cores.
Old Jan 14, 2018 | 05:39 PM
Mark Shead's Avatar
Mark Shead
Garrett or cfs cores are for me the only ones to go for.
Mark
