DAB radio...Help
You need to follow the fitting instructions quite carefully. There is a Earth lead that glues to the window pillar and the aerial needs to be away from heated screen element and use the cleaning pad that comes with it.
CheeRs for the heads up ..do you know how the A pillar trims come off the Audi TT ?
Also, one odd thing was that the tt has a different wiring to normal in that the yellow was switched live and red was perm so check that with a test light. Mine has Bose but it is just a normal blue remote on wire.
I fitted a dab radio in my mk4 golf got an eBay 30 odd quid aerial and couldn’t pick up shit lol. Went to a local stereo specialist and he said the aerial I’ve used will work as an fm aerial but be useless as a dab one. Got his cheapest which was 130 quid now it works spot on
I have to agree with Andy most dab aerials are rubbish even the ones that sony provide.
best aerial is one that converts the original to dab via a splitter or a dedicated dab external aerial.
I am having trouble finding something suitable for the saff.
Yes, you pull the door trim rubber off and then the door pillars pop off, watch it though as the plastic fittings have gone brittle on mine and 2 broke, I am going to tiger seal them back together as it rattles a bit now (I am sure the Roadster is worse though). On the Roadster the pillar trims lock in to a plastic cover with the sun visors in, I had to pop off a corner to get the pillar off.
CheeRs mate thought so ..i too have the red and yellow live and switched live ..ill get it sorted tomorrow .
Also make sure whichever one you choose that its connected to a switched live not the antenna blue wire as this is only live when normal radio is on not dab.
Hope it works i am on my 3rd aerial with no luck.
Thanks mate ..yea I'll make sure ..mate of mine has the same antenna in his Honda and it works a treat so fingers crossed.
I have tried one of those splitter types with amp which uses the original focus aerial. it worked ok when i tuned it in bit now it dont will have to check connection.
Thinking i might try it on the saff but disconnect the ford amp.
I had one of those stick on aerials in an old car, it was alright, certainly no where near as good as a factory fit dab aerial but good enough. I did look in to changing it for a powered external dab aerial but decided to buy a new car already with dab instead
Well had a result of a day ..took me an hour to fit ..and works fantastic..its so much clearer and bass over the normal tuner ..well worth the 12 Quid
Good news, the 2 kenwoods I bought off 1 pd on here both came with stick on aerials and they seem to work a treat. I think the one in the TT works better than my new shape Range Rover one but I also struggle with mobile phone in that and someone said it was the double glazing and all the heated screens.
I've used a new alpine head unit and the 12 quid dab antenna mounted in the passenger top corner of the front screen its made a right difference .
We use dension antenna, at work. I always test them before stick it on the window, they work, but the best signal is when they are grounded at the a-pillar an stick on window. We mounting alot of these, as the fm band, is closed here in Norway
