Sierra Cosworth handbrake cables
Hi everyone
I have a Capri Perana fitted with Cosworth rear brake calipers.
Currently there are no cables attached.
I have the correct cables but I am desperate for some pictures of how the cables run and are fixed to the Sierra.
If anyone has some pics showing how the cables fit to the car it would be very helpful.
Many thanks Chris.
Many thanks Chris.
You will have to use the capri horse shoe not the sierra one as they are too wide.
your brackets on the capri on the tunnel will need opening out or new brackets fabbed up.
As for the routing of cables to calipers its where ever it fits and is away from moving shocks and propshaft.
will try and dig a pic out of cable to caliper for you.
Gav Diamond
Apr 22, 2013 05:28 PM
lawnsy
Aug 18, 2008 12:49 PM
