wiring ratings
Old Dec 13, 2017 | 01:19 PM
dojj's Avatar
dojj
Resident Wrestling Legend
Default wiring ratings
after getting no replies from anyone else, i'll post here
the yellow wire on the left is what i have in the car right now to supply power to the head unit
the head unit then supplies power to the 2 head rest screens and the remote powers the amp
the wire on the right, orange with the black stripe, is the wire that's come with the loom for the new headunit i've got
this wire also powers the dvd player under the seat, both headrest screen, the 6 changer 6 box and the sat nav dvd player
the remote feed doesn't do these things
both of these wires need to be the memory feed for the radio so it's not a case of running another wire with a relay for a switched ignition feed
so my question is this
am i ok to run the power from the original wire? seeing as it's deemed to be suitable to run stuff as it's the patch lead between old and new or do i need to run a new wire?
what would you do?
because the wiring instructions to retrofit the stuff i'm fitting say nothing other than just plug and play it all together so am i over thinking this or am i playing it safe?
cheers
Old Dec 13, 2017 | 02:22 PM
djmca's Avatar
djmca
Bring back old skool Ford
Depends on the size of the wire really
As its only low voltage (12/24v DC) and low current draw i would not be concerned.
Old Dec 13, 2017 | 03:04 PM
dojj's Avatar
dojj
that's what i thought, but seeing as there is a wire running alongside it for the fag lighter plug i'm going to use that instead
the fag lighters been replaced with a usb set of plugs and i've got another one in the car anyway in case i need to use it so job jobbed
Old Dec 13, 2017 | 03:12 PM
djmca's Avatar
djmca
Just be careful that you dont cause interference by doing that. A radio or similar can be very easily upset by electrical interference and if you have something plugged in to the cigarette lighter it may cause you problems
Old Dec 13, 2017 | 03:33 PM
dojj's Avatar
dojj
i know if i charge my phone in the non usb version it caused all sorts of interference but with the dedicated usb charger ports wired up that's gone away
Old Dec 13, 2017 | 06:54 PM
RichieST's Avatar
RichieST
The thickness of insulation on the wire can be deceiving, there could be less wire strands in the orange cable than the yellow. As long as the wires are adequately fused then I don't see an issue. Personally, I would want each item run from an individually fused distribution block, but that's up to you.
Old Dec 13, 2017 | 08:11 PM
I powered my dvd head rest from the permanent live from the electric front seat.
What radio are you using Dojj??
Old Dec 15, 2017 | 02:48 PM
dojj's Avatar
dojj
i'm retro fitting the ford sat nav unit
it's a bit complicated to say the least
i've had the car apart for weeks now because i do bits at a time, but it's an almost full interior strip out as the carpet and complete dash has to come out in order to run the wires
plus a lot of the wires are in different places to the normal stereo set up
then you have to figure out the can bus and the headlining has to come out because of the ariel and all sorts
this is before you figure out that the new wires you need to run are too fat to fit into the normal clips, i've already broken a side panel trim and the seat belt cover
also got the strip the seats down as they've got the headrests in them and the motor for the 8 way seats gets in the way of the dvd unit
i'm also going from pre face lift heated seats to face lifted climate seats
and while i'm there i'm going to fix the handbrake switch
Old Dec 16, 2017 | 08:53 PM
I fitted an aftermarket head unit to my mondeo. It's got everything,dvd,sat navigation,Bluetooth,cd player sd card reader. I've also got 2 head rest monitors and a reverse camera wired into it.
mxquattro
Ford Escort RS Cosworth
Sep 29, 2006 12:33 AM
Fiecos Dan
Aug 3, 2006 05:50 AM
Azrael
Feb 16, 2006 09:23 AM
markk
11
Jan 26, 2006 10:43 PM
MGTurbo
Apr 3, 2005 01:48 PM
