Retro fitting Air Con to 3dr Cosworth
Hi all I'm new to this site and just bought my school boy poster car a 1987 3 door Cosworth that's had a nut and bolt restoration, its like brand new. The car is totally original and i'm not planning to modify it as i just want to keep it original but i do need to look at installing Air Con. I live in Australia so the car will never rot out here but in order for me to drive it occasionally i need to find some way to cool it internally.
Does anybody know if its possible to buy a ford kit that can be retrofitted or does anybody even have a system that will work i can buy from you please?
Many thanks
Many thanks
Ford originally did a dealer fit kit for the lhd sierra markets fitted with a pinto, my RS500 had it on from new as did a few 3drs.
Given your location then an aftermarket pinto kit for an escort or Cortina would do the job.
Martin at Reyland motosport retro fitted a sapphire kit to his RS500, it does need the bulkhead modifying, using the buldge from a air con equiped car plus lots of other mods, worthwhile mod due to your location tho,
I have a spare sierra air con kit here with most of the pipes, compressor, rad brackets etc
steve
steve
I have also retrofitted aircon to my Sapph, it's in the project thread of my 24v Sapph. You can clearly see the bulkhead that needs to be changed. I guess it won't be much different on a mk1 Sierra.
Many thanks
Many thanks
I just took everything from a ghia,and converted the belts to poly-v belts,using the big heavy bracket they used on the 4x4 saph to mount the alternator etc...
