L8 CO2 screw start position.
Old Nov 20, 2017 | 07:29 AM
kiwikermit's Avatar
kiwikermit
Default L8 CO2 screw start position.
Hi I have a used L8 ECU that I am replacing the chip in. Is there a way of confirming the CO2 screw is in the correct start position before performing the clockwise-anti clockwise procedure? The ECU I have already had a chip fitted so not sure if I will be starting from the correct position.
Old Nov 20, 2017 | 08:28 AM
steppy's Avatar
steppy
Don' do any adjustments without a co meter
Old Nov 20, 2017 | 08:55 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
Turn the CO pot 5 turns clockwise then precisely 2 turns anti-clockwise, this will set you at what we call zero pot position
Old Nov 20, 2017 | 08:49 PM
kiwikermit's Avatar
kiwikermit
Thanks.
