ST170 mk3 Mondeo front calliper differances.
Old Nov 17, 2017 | 05:23 PM
big_wasa's Avatar
big_wasa
Default ST170 mk3 Mondeo front calliper differances.
I’ve read the mk3 Mondeo front calipers can be used as a 300mm upgrade on a Sierra with the St170 discs.
But can the ST170 calipers be used ? I have all four corners that I keep tripping over.
Old Nov 17, 2017 | 06:08 PM
dojj's Avatar
dojj
Resident Wrestling Legend
depends on what car you are fitting them to
Old Nov 17, 2017 | 06:15 PM
big_wasa's Avatar
big_wasa
Kitcar with Sierra front hubs.
Old Nov 18, 2017 | 04:20 PM
dojj's Avatar
dojj
as long as you can run 16" wheels it won't matter
the focus ones are supposed to be slimmer so that you can fit them under certain 15" wheels but the main issue is going to be the offset on the "ears" and the requirement to fit a spacer between them
the st170 has a top hat of 44mm from memory
Old Nov 18, 2017 | 05:29 PM
big_wasa's Avatar
big_wasa
Hmm thanks I won’t bin them just yet then but I really don’t won’t to go over 15" rims
Old Nov 18, 2017 | 05:32 PM
big_wasa's Avatar
big_wasa
Can I ask what you mean by top hat ? I know my way around a Zetec or two but I havnt played with brake swaps much.
Old Nov 18, 2017 | 08:35 PM
I had mk3 mondeo calipers and ST170 front discs under my Ford pumas 15inch wheels. I had to trim the calipers a bit. I had them on the car for over a year with no problems.
Old Nov 19, 2017 | 08:54 AM
dojj's Avatar
dojj
"Top hat"
Old Nov 19, 2017 | 05:33 PM
big_wasa's Avatar
big_wasa
Thanks, it dawned on me after posting that was what you meant.
