How to empty the fuel tank on a 1.8TDCi Focus
Old Nov 16, 2017 | 01:53 PM
Hotblack's Avatar
Hotblack
Default How to empty the fuel tank on a 1.8TDCi Focus
Hello all, first post so my apologies for what could be an easy fix but I'm not a mechanic so please go easy on me.
I've had a Focus 1.8 TDCi hatchback sat in a garage for 3 years (waiting to be converted to Spanish plates) with a 1/4 of a tank of diesel in it. I realise now I shouldn't have just left it like that but from what I've read, the fuel has gone bad and needs to be replaced.
I've tried syphoning it out but all methods on YouTube have failed. I've looked under the back seats but can't get access to the pump to syphon it that way and I've tried disconnecting a fuel line, turning the ignition switch a couple of notches but that didn't produce any fuel either. I’ve read quite a few posts saying that the last method works but they all assumed the person reading knew where about to disconnect the fuel line. I have attached a phone of where I disconnected the line as there is a nice easy joint but I’m guessing this may not be the right place to do it?
So in a nutshell, what’s the best way to drain ¼ of a tank of diesel and if it is by disconnecting a fuel line at the engine and turning the ignition on and off, where about do I disconnect it?
PS I’ve changed the battery and the oil (and filter) but I’m a little hesitant about changing fuel filters as I’ve read too many posts about cars not starting because of air in the system and not being primed and then I start to feel out of my depth so was hoping to just remove the fuel and then let the garage change the fuel filter and air filters (haven’t even looked into how you do that yet but may do if I feel brave...and if it is easy) and whatever else should be changed after sitting for 3 years.
Attached Thumbnails How to empty the fuel tank on a 1.8TDCi Focus-1.8tdci.jpg
paceo
Sep 17, 2015 12:12 PM
jessie_rs
Jan 22, 2008 11:27 AM
Olliexr4x4
Jan 5, 2007 05:26 PM
Mr C
16
Jul 7, 2006 10:21 PM
CarismaDave
Jan 19, 2006 09:20 PM
