Ford escort rs 2000 convert to cosworth with mechanical parts from sierra cosworth 4x
Old Nov 8, 2017 | 03:08 PM
kakoulas123456's Avatar
kakoulas123456
Default Ford escort rs 2000 convert to cosworth with mechanical parts from sierra cosworth 4x
Hello guys , I want to ask a question. As the subject says, I have an escort rs2000 mk5 and I want to convert it to cosworth with floo pan from sierra cosworth 4x4. I think the genuine escort has floor and mechanical parts from sierra cosworth 4x4.Can i make it or not.Thanks
Old Nov 10, 2017 | 10:28 AM
cutch's Avatar
cutch
Series 1 4x4 cossie
You can make anything you want from the pats if you have enough time and money. The Sierra floor pan is longer than your escort so you will need to cut and shut it. This needs to be done properly of course for strength etc. I have done the conversion to my mk3 escort which is basically the same. Have a look at my build thread in my sig. there is plenty of other guys on here that have done the conversion too, there’s loads of threads with basically the instructions how to do it! Just have a look.
Old Nov 10, 2017 | 04:49 PM
Adam-M's Avatar
Adam-M
There was someone on here who built a red escort cosworth out of a base model shell and a sierra floor, car looked superb finished but fabrication work looked questionable tbh.
My only advice would be take the shell to someone with experience in this to be welded together, like AG Motorsport ect
Edit to add I just noticed your in Greece lol
Old Nov 10, 2017 | 05:08 PM
Caddyshack's Avatar
Caddyshack
Are we talking mk2 escort 1970s or 1990s rs2000? If it is a newer version I would start by buying a 4x4 rs2000 as they did make them and the floor pan of that would be roughly same length as escort Cosworth...I would buy a cossie shell though.
If you are talking mk2 then I would fit a mistubishi evo floor pan and drive train...that would be far cheaper without the cossie tax and much stronger with a much bigger parts supply.
Old Nov 10, 2017 | 05:10 PM
Adam-M's Avatar
Adam-M
Says mk5 in opening post mate
Old Nov 11, 2017 | 09:07 AM
Dubs44's Avatar
Dubs44
https://passionford.com/forum/restor...ll-to-rwd.html
Old Nov 11, 2017 | 09:34 AM
Caddyshack's Avatar
Caddyshack
Oops, so it does.
Isn't the rule to never build what you can buy so surely best bet is to buy a cossie shell or a 4x4 RS 2000 if you can find one?
Old Nov 11, 2017 | 11:25 AM
jonfoc's Avatar
jonfoc
Oops, so it does.
I reckon the price of converting would be similar to buying a genuine shell. There's been a few on eBay recently. Dingla and MK Motorsport can do I nice conversion though
Old Nov 13, 2017 | 07:41 PM
dingla rs's Avatar
dingla rs
Around 4k to convert it
Old Nov 14, 2017 | 11:23 AM
Caddyshack's Avatar
Caddyshack
Dinglas shells are superb
Old Nov 14, 2017 | 07:44 PM
I 100%agree.
