Fiesta Mark 3 Gearbox Question
Old Oct 30, 2017 | 12:43 PM
Fiesta1.8grasstrack's Avatar
Fiesta1.8grasstrack
Default Fiesta Mark 3 Gearbox Question
Hi Everyone
I've just purchased a Fiesta Mark 3 1.3 which has been fitted with the 1.8i Zetec engine
which I plan on using for grasstrack racing locally
the car has unfortunately got a burnt out clutch right away which I've managed to source one for
but I'm now planning whether to install the original gearbox or look for something different
are there any stronger gearboxes I could use in this one / factory LSD boxes which aren't going to cost the earth
as its just a hobby of course
thanks for your time!
Old Oct 30, 2017 | 02:51 PM
james kiely's Avatar
james kiely
stick a rs turbo gearbox on it ,probably cost 250/300 for a decent box
Old Oct 31, 2017 | 11:40 PM
Rich87's Avatar
Rich87
Or a ib5 gearbox bit stronger than a rs box and depending on what car you get it out of very similar gear ratios, the escort rs turbo lsd will fit in both but buying a second hand one if you can find one will cost best part of £150
