Can a Cosworth L6 ECU with wasted spark run coil on lead
Old Oct 19, 2017 | 06:37 PM
rs milesy's Avatar
rs milesy
Default Can a Cosworth L6 ECU with wasted spark run coil on lead
I am looking at what options I have with my zetec turbo S1 project, I have had it running on the Cosworth L6 ECU which is fitted with wasted spark kit, Thing is the coil pack is in the way of the boost pipe to the inlet, which makes me wonder if the L6 could run coil on plug, and what's involved, any ideas ?
Thanks
Old Oct 19, 2017 | 09:40 PM
martysmartie's Avatar
martysmartie
No, it can not. Can the coil pack be relocated?
Martin
Old Oct 20, 2017 | 05:17 AM
rs milesy's Avatar
rs milesy
That looks like the other option, but it is pretty tight in there, thanks for the info.
