Sierra Cosworth wont go over 3krpm
Old Oct 17, 2017 | 03:43 PM
hazelmurphy's Avatar
hazelmurphy
Default Sierra Cosworth wont go over 3krpm
The timing belt, rocker gasket, crank seal and two cam seals were done in my cosworth and timing has been double checked. It is limited to 3-3.5krpm., hitting the limiter. Any ideas what could be wrong?
Old Oct 17, 2017 | 04:22 PM
lacey's Avatar
lacey
I had this years ago with my motor 3k then dead cut/limiter
It was the Ecu
Changed that and it was tip top again
Hope this helps
