advice on forged pistons
Hi guys
I'm doing a full rebuild on my engine
I need to get new set of pistons (rebore)
so it seems currently I can only get the wossner one (forged)
or the mahle / semi forged / like original so I need to get those pistons modified for high lift valve
appear of wossner ? today can I get an other set of pistons ?
best quality required
thanks for your help
What size over-bore do you require?
I believe CP Pistons to be of the best quality but maybe overkill depending on your power? Cosworth pistons are good aswell if they are still available, I run Accralites from burton power I think they are a copy of Cosworth pistons not sure.
I have Wossner pistons in mine. Apart from being a bit noisy when cold, they seem fine.
Depends on your budget. Start going for CP etc, then prices do start to climb quite rapidly
http://www.performanceunlimited.co.u...ds/cp-pistons/
My son's had SuperTech pistons fitted into his forged Focus RS engine, they might be worth a look too
thanks guys (I do a request for CP pistons)
regarding lot's of posts it seems the mahle one are good for 500HP
I'm looking for 380 / 420 really maximum HP
is it true
or it's better to go on wossner or CP pistons when you rebuild the engine
you can get mahle with valve cut off too
is it true
is it true
is it true
Hi again guys
no mahle available in France so 2 choices:
brutonpower (available)
or Brands Hatch Performance
1- BHP could be good cause this company do the cut off but ... I don't know them and don't know if they are serious or not
2- burtonpower sells Accralite and Mahle and price is similar
it seems mahle brand is better than Accralite
correct ?
last question ... I start to calculated the compression ratio and I do not have the piston
what is the "standard" deck value for Mahle pistons ?
thanks
correct ?
thanks
I wouldn't say Mahle's where better no, accralite are proper forged and manufactured to very high modern standards where as the mahles are old and high pressure cast, both good pistons though.
I have only used BHP for small purchases and haven't had any issues on them.
Hi again guys
correct ?
thanks
correct ?
thanks
Mark
