How to test the silver ECU
Old Sep 29, 2017 | 07:38 PM
luxembourgrst's Avatar
luxembourgrst
Default How to test the silver ECU
hy i have a turbosystem chipped ECU
my question is how can i check if my ECU still work propely as my car do not wanna start cuts off after 1 second start...
Old Oct 20, 2017 | 09:19 AM
Karlos G's Avatar
Karlos G
Balls Deep!
The silver ECU controls the spark so if you are sparking then it's at least working to some degree.
Cutting out after 1 second is more likely air/fuel related
