TPS problem or not ?
I had a problem with the car over fueling on boost so replaced the map sensor and it has cured the problem but since changing it my monitor shows my TPS % jumping all over the place. At idel it reads o% but if you just touch the throttle it jumps to about 80% and then jumps all over the place.
Car drives fine with no holding back or missing so is it a faulty TPS or just the monitor not picking up the reading correctly.
Just seems strange it started after replacing the map sensor.
2wd cosworth on pectel T2.
