Cosworth 4x4 caliper conversion on series 1 rst
Old Sep 14, 2017 | 09:50 PM
24psi boost's Avatar
24psi boost
Default Cosworth 4x4 caliper conversion on series 1 rst
I am planning to do the cosworth 4x4 caliper conversion on my rst, but am having trouble sourcing the 4x4 calipers, can anyone confirm exactly which other Ford cars have the same calliper fitted?
Thanks in advance
Old Sep 15, 2017 | 06:08 PM
Marc sierra's Avatar
Marc sierra
As far as I know the Granada and Scorpio 24v Cosworth and the Mondeo mk1 and mk2 2.5 V6. But the caliper carriers might use an m12 bolt instead of an m10.
Old Sep 15, 2017 | 08:15 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
sapphire 4x4, escos and granada cosworth all have the calipers. unsure on the mondeo v6 though but it's highly likely. granada caliper carriers are m12 for sure as i have a set here that i removed last week.
Old Sep 16, 2017 | 08:49 PM
The Youth.'s Avatar
The Youth.
As said the Mondeo Mk1 and early Mk2 up to 1999 have the same caliper but the carriers have m12 bolts which won't fit, the Granada Cosworth is the same caliper and carrier as the 4x4 Cosworth
Steve
Old Sep 16, 2017 | 09:16 PM
Mark V8's Avatar
Mark V8
I'm pretty sure some TVR's had them
http://www.ebay.co.uk/itm/2005-TVR-T...IAAOSwmgJY5Rqp
Old Sep 18, 2017 | 01:18 PM
ricky's Avatar
ricky
Got a pair from my 4x4 if instered
Old Sep 23, 2017 | 08:31 PM
Brendan's Avatar
Brendan
struggling with reality
I have a set on my FRST and they work very well! just make sure that you clean the piston off very well as they had a habit of sticking when rusty! I made a set of pistons in stainless, so mine won't go rusty!
