Engine swap for Ford Mondeo mk3
Old Sep 14, 2017 | 07:48 PM
Konnanokk's Avatar
Konnanokk
Wink Engine swap for Ford Mondeo mk3
Hello
Im looking for a fast engine for my ford mondeo mk3 from 2004. I dont know what fits and works tho. I would like to get about 300 bhp. Got any ideas what would fit? I think i will add a turbo too. Just want a fun sleeper.
Old Sep 15, 2017 | 07:05 AM
Bailes1992's Avatar
Bailes1992
The MK3 Mondeo was available with the Duratec 2.0 as fitted to the Fiesta ST.
I would look to see what they are doing to get that sort of power.
If it was me I would be looking at a 2.5 i4 Duractec with forced induction.
Old Sep 15, 2017 | 08:13 AM
I wonder if a focus mk2 st engine would fit.
They are fitted in the mk4 mondeos as stanard.
Old Sep 15, 2017 | 06:01 PM
big_wasa's Avatar
big_wasa
So the mk3 came with,
1.8 Duratec i4
2.0 Duratec i4
2.5 Duratec v6
3.0 Duratec v6
The 2.0 is the same engine as the st150 but it's only 5bhp up on the Mondeo so not worth the bother. The St150 uses the Mazda ecu. Both will do 200 by freeing up the induction and exhaust but that's not going to feel quick in a Mondeo.
The Mazda 3+6 MPs is a 2.3 stroked and turbocharged version of the 2.0 and should bolt in and give you the power you want but they are rare and expensive over here.
The 3.0 v6 from the st220 is erm 220bhp ish but it feels slow compared with a boosted car with the same power and 2/3 the weight. I.e. I have an st220 and a Megane 225 and you can't beat some boost.
The 3.0 v6 is what Nobble used with a couple of turbos to give around 400bhp. It just used 1mm shorter forged rods.
(If you find some let me know)
As above the Volvo/ Ford 5 pot fits between the legs of the mk4 so will likley do the same in a mk3 but check out engine manegment systems for a five potter before you start.
If you can fabricate stuf then pic any engine that makes the power your looking for and bung it in the hole. Don't forget a project thread with lots of photos.
What I want to know is, has any fitted a 2.0 Zetec ? ?
Old Sep 16, 2017 | 08:31 AM
Top info there. I was reading about the v8 mk3 mondeo touring cars last night.
Old Sep 16, 2017 | 09:32 AM
Adam-M's Avatar
Adam-M
I'd save myself the hassle and buy something like an Impreza blobeye (03-05). Similar sized to a mk3 Mondeo and has a better platform.
Old Sep 16, 2017 | 01:01 PM
big_wasa's Avatar
big_wasa
Yep my bugeye has to be my favourite motor ever but they have plenty of there own problems.
Old Sep 16, 2017 | 01:42 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
whats the biggest engine ford did for the Mondeo? do people still do cosworth conversions or is that to old school nowadays?
Old Sep 16, 2017 | 03:32 PM
bj928's Avatar
bj928
the new mustang has the duratec 2.3 ecoboost, 300hp, and should bolt straight in, bit pricey still but a simpleish swap, even though the mustang is RWD, don't think it would be difficult to swap, maybe use some of the mazda 2.3 parts
Old Sep 16, 2017 | 03:34 PM
big_wasa's Avatar
big_wasa
From factory it's the 3.0 st220.
I think you would need very deep pockets for a complete and running cossie engine these days.
What's the going rate ? I've seen posts where just a good head is worth thousands.
Old Sep 16, 2017 | 03:40 PM
dojj's Avatar
dojj
Resident Wrestling Legend
an easy enough swap for the focus 5 pot other than some wires
Old Sep 16, 2017 | 05:37 PM
Fartblood's Avatar
Fartblood
Erect Member
2.3 Ford block. Turbo. Sorted.
Old Sep 16, 2017 | 06:50 PM
st220kyle's Avatar
st220kyle
Wasn't there a bloke on here fitting a dodge viper engine in a st220? What happened to that?
unless money is no object, I would just get an st220 or something else all together
Old Sep 16, 2017 | 11:27 PM
burnzy's Avatar
burnzy
burnzy
What about fitting a z20let out of a Vauxhall, cheap, transverse, easy enough to reach 300bhp, fit in the space available, either run standalone management or try and graft in the Vauxhall ecu into Ford chassis, can't see it being that hard to be fair.
Old Sep 18, 2017 | 09:01 AM
There was a mondeo st220 on ebay a few months back that had been turbo charged. It needed finishing of. I think he wanted 5k for it
No wonder people walked away from ford cause they wanted a performance car. There was way better cars out there like the impreza and evo.
What did ford have to offer? A big heavy mk3 front wheel drive mondeo with a 3.0 ltr na engine.
Old Sep 18, 2017 | 10:07 AM
Fartblood's Avatar
Fartblood
Erect Member
The mondeo still outsold the Prezza 100:1 though, so as a money making exercise Ford knew exactly what they were doing.
