Clear perspex moulding ..who does it .
Old Sep 13, 2017 | 08:04 PM
Rsmat's Avatar
Rsmat
Default Clear perspex moulding ..who does it .
As title who makes things out of clear perspex to a good standard ..any companies ? Or persons ? ..im after a cambelt cover making for my cvh rs turbo ..i did buy one bit it arrived cracked in the corner ..and I'm quite guttered after looking for one for ages and then this comes up and arrives cracked.
Thanks Mat.
Old Sep 13, 2017 | 08:46 PM
Mark V8's Avatar
Mark V8
I've used this stuff to fix acrylic parts together in the past
http://uk.rs-online.com/web/p/acryli...sives/0144406/
It's really thin and flows into cracks and joins welding the material together.
Best used with a syringe and needle (I used to work in a hospital!)
Old Sep 13, 2017 | 09:29 PM
Rsmat's Avatar
Rsmat
If it would get rid of this id use it ..but I can't see this being repaired
Old Sep 14, 2017 | 06:28 PM
Fullflush's Avatar
Fullflush
Did the postman run over it with his van
Old Sep 14, 2017 | 07:13 PM
RSmark84's Avatar
RSmark84
Half of the crack would be covered from the rubber gasket(are you going to staple it in?) you could tiger seal the gasket on. The other half you could hide it by sticker the inspection/test OK sticker over it, Or even a cambelt change sticker. If not there's a long ford service sticker you can fit over it.
Old Sep 14, 2017 | 09:20 PM
Rsmat's Avatar
Rsmat
What do you think ?
Not a bad idea that .. but ive gone for a full refund and return it ..ill have a carbon one made now .
Old Sep 14, 2017 | 09:32 PM
Fullflush's Avatar
Fullflush
I'm thinking it probably was like that when it was sent?
I can't see any skid marks on it
Old Sep 15, 2017 | 05:13 AM
Rsmat's Avatar
Rsmat
Im thinking the same tbh ..but either way it's getting sorted ..would like another though .
