any mot testers on here ? question about advisory
ok guys been looking for a car. seen a cat c low milage car and checked the reg on mot history.
12 july 2017 : mot pass
Advisory notice item(s)
Offside Front HUB COMPONENTS CORRODED
Offside Front Inner Front constant velocity joint gaiter damaged, but preventing the ingress of dirt (2.5.C.1a)
exhaust corroded
Offside Front Track rod end ball joint dust cover deteriorated, but preventing the ingress of dirt (2.2.C.1c)
sill covers fitted
Rear Exhaust has a minor leak of exhaust gases (7.1.2)
6 july 2017: mot fail.
Reason(s) for failure
Offside Front Track rod end ball joint has excessive play (2.2.B.1f)
Nearside Front Body or chassis is damaged, seriously affecting its strength within 30cm of the body mountings chassis leg (6.1.B.2)
Emissions not tested (7.3.A.1)
Exhaust system not adequately supported (7.1.1)
Supplementary Restraint System warning lamp indicates a fault (5.4.2)
Passengers airbag obviously defective (5.4.1)
exhaust corroded
sill covers fitted
just a bit curious it went in for mot it failed 6 days later it passed?
and one thing thats got me kind of worried on Advisory notice when it failed was
"Nearside Front Body or chassis is damaged, seriously affecting its strength within 30cm of the body mountings chassis leg (6.1.B.2)"
does that mean the chassis is bent? should i be worried? as it passed 2nd time.
thanks in advance
exhaust corroded
sill covers fitted
exhaust corroded
sill covers fitted
thanks in advance
rsguy. What car is this and what mileage has it done? It would put me off buying it, to have passed within 6 days of failure on such a major front body or chassis damage means someone must have done a lot of welding etc to get it through. Hard to know unless you can find out exactly what was wrong and what has been done to rectify it.
If it is not being sold for a real knockdown price I would be looking elsewhere. There seems to be a lot of potential problems which may end up being a right pain.
