Sierra Engine???
I have a 1989 Sierra Sapphire running a 2.0 pinto engine, It has twin 40 carbs too, The engine is tired and burning oil, So as my winter project I am going to sort the engine but I am torn on which way to go.
I have a few options, I don't have the money to buy a cosworth engine so things will be done on a cheaper scale.
My options are as follows:
1. Stick with the 2.0 pinto engine and rebuild it and do head work and camshaft and keep the carbs.
2. Ive got a low compression Pinto engine so thought about doing a Turbo project.
3. Get a 2.0 Ztec engine and convert that to fit.
Im be doing all the work myself, I must admit I do like the carb noise but want a bit more power too.
Thanks
Thanks
Or
Buy a ST 170 engine which will fit on your type 9 box.
Or try and source a granada 2.3 16 valve and tranfer the lot over.
Or just a 2.0 black top zetec which is a step backwards from the duratec badged ST 170 zetec.
Could even use your carbs
How about getting a black top Zetec for Ł975 on ebay and a set of motor bike carbs with ignition mapping from Chester sports cars for Ł980 this will give you about 160 BHP with decent economy and performance.
http://www.ebay.co.uk/itm/182756980475
http://www.chestersportscars.co.uk/
Maybe not too much money for a new engine & BHP!
I started but never finished a Zetec Sierra. There are worse engines than a Zetec and they can be very very cheap.All down to your budget and how much you can add by fabricating parts.
